Author Topic: stereotype <<entity>> without image with circle  (Read 10483 times)
jumbie
« on: October 10, 2021, 05:28:56 pm »
Hi all,
I want to use a stereotype "entity" for a class,
but without a circle image with the line below.
I need an implicit rectangle image of the class.
How do I turn off this circle image for entity stereotype?
Thanks for the answer,
Jumbie
« Last Edit: October 10, 2021, 05:54:42 pm by jumbie »
Re: stereotype <<entity>> without image with circle
« Reply #1 on: October 10, 2021, 08:57:39 pm »
Right out of my head there's a Use Rectangular Notation somewhere in the context for some elements. Might be also for this one?
jumbie
« Reply #2 on: October 10, 2021, 11:30:42 pm »
thanks, but it is not possible to switch this notation for a class. The change is made by stereotype.
« Reply #3 on: October 11, 2021, 12:38:33 am »
Yes, not possible for that stereotype (just had a look). You would need to create your own stereotype and add a diagram property to appear in the context so you can change the rendering. We use thar for quite a few stereotypes.
jumbie
« Reply #4 on: October 11, 2021, 03:11:54 am »
OK, I assumed it, I needed to verify it, thanks!
Takeshi K
    • Sparx Systems Japan
« Reply #5 on: October 11, 2021, 01:45:16 pm »
Hello Jumbie,
Try to turn off the setting 'Use Stereotype Icons' in teh Elements group, diagram properties dialog.
(double-click a target diagram background to open the dialog)
t-kouno
jumbie
« Reply #6 on: October 24, 2021, 02:36:32 am »
Thanks a lot, it works!
Jumbie
