Author Topic: Default selection for Link to Element Feature dialog is "none"  (Read 18288 times)
« on: October 21, 2021, 11:03:26 pm »
Can someone please explain to me the reasoning behind the choice "none" as the default selection for the Link to Element Feature dialog?
One would assume that the default option should be the one that is most often used. I personally think the option "attribute" is used in more than 99% of the cases, but yet "none" has been choses as the default value.
I'm pretty sure the actual usage of "none" is 0%. Nobody chooses the option "Link to Element Feature" in order to not link it to an element feature.
This type of thing is very hard to explain when giving a demo or explaining a this feature. I usually resort to something like "yeah, weird choice, you know Aussies and all"
Re: Default selection for Link to Element Feature dialog is "none"
« Reply #1 on: October 21, 2021, 11:10:54 pm »
One would assume that the default option should be the one that is most often used. I personally think the option "attribute" is used in more than 99% of the cases, but yet "none" has been chosen as the default value.
This type of thing is very hard to explain when giving a demo or explaining this feature. I usually resort to something like "yeah, weird choice, you know Aussies and all"
"Hush yo' mouth, sah!"  Your comment is an affront to those of us who live in 'straya!  Since the Sparxians live on planet Sparx, you can "dis" them all you want.
As you'd guess, I can't explain it, other than to observe that the meaning of the term "default" is more usually used "in the breach, than in the observance".
« Reply #2 on: October 22, 2021, 05:24:50 am »
My 99% are the element notes. So they propably decided fot the "dunno".
« Reply #3 on: October 22, 2021, 08:07:52 am »
At a guess, the dialog is showing the current selection like any other property.
« Reply #4 on: October 22, 2021, 09:14:12 am »
<sound>LOUD Klaxon...</sound>
Then it's not a default!   There are two components to the dialog, the type and the value.  When there is NO link, the type should default to "Attribute" and the selection show <none>.  When a link exists, it should show both the type and the value of the link.  In my 10 years of use of this feature, I don't believe I have ever changed a setting in this dialog, once initially set, although I concede there is a use case for it (but it should be rare).
« Last Edit: October 22, 2021, 09:20:17 am by Paolo F Cantoni »
« Reply #5 on: October 26, 2021, 09:33:15 am »
I never said it's a default.
The current setting is that no Feature Type is selected, not just that no attribute is selected.
So, my answer to Geert's original question: Because it's showing the current value, not the default.
« Reply #6 on: October 26, 2021, 10:41:07 am »
I know, Eve, you didn't say default!
My point was that if there is no setting, we expected a default value to be suggested.
« Reply #7 on: October 27, 2021, 07:49:15 am »
Same for us, but the most useful setting where the current setting is "None" would be the last value that was entered by the user to replace "None".
