Author Topic: is the ExitPoint dead?  (Read 11132 times)
linexc
« on: October 25, 2021, 08:26:52 pm »
Hello Community,
I am using EA 14 and my colleague using EA15. But both of us have a problem while trying simulate the statemachine with an ExitPoint. As what you can find in the imgur link, the state transition from state1 to state2 does not work after I activate the trigger "test". The exit operation inside State3 contains the code as :
System.out.print("first statement.");
this.m_StateMachineImpl.m_pManager.BroadCastEvent("ExitConrurrent2");
BTW, the system.out.print does not work either.  :'(
It would be super nice if you can figure it out.
https://imgur.com/a/1A2exKc
Look forward to your reply.
Linexc
Re: is the ExitPoint dead?
« Reply #1 on: October 26, 2021, 09:34:09 am »
It needs to be owned by the state that is being exited.
linexc
« Reply #2 on: October 26, 2021, 05:34:57 pm »
Hello Eve,
thanks for your reply.
Do you mean the ExitPoint should be placed as the screenshot in the link below? But there is no difference between the both results of simulation.
https://imgur.com/a/RdBPVcG
BR
Linexc
« Reply #3 on: October 26, 2021, 07:43:20 pm »
I don't think the placement on the diagram is an issue, but rather where in the project browser the Exitpoint lives.
It should be nested under (=>owned by) State1
linexc
« Reply #4 on: October 26, 2021, 08:01:22 pm »
Hello Geert,
Thanks for your reply.
I can confirm the ExitPoint is nested under state1. But the problem exists still.  A screenshot of the project browser can be found in the link below.
https://imgur.com/a/pyeSNIU
BR
Linexc
