Author Topic: Project Integrity Check: No jump to element?  (Read 10563 times)
EAabecedarian
« on: October 25, 2021, 11:47:03 pm »
Hi EAexperts.
Somewhere I read the recommendation to run the "Project Integrity Check" as often as possible, which sounds quite reasonable.
I understand that if someone follows that recommendation, the result list may be very short and it's easy to find where the integrity issue was caused.
Out of curiosity, I ran it for the Autosar BSW UML model (https://www.autosar.org/fileadmin/user_upload/standards/classic/20-11/AUTOSAR_MOD_BSWUMLModel.zip).
It tells me about 1200 inconsistencies as a long list with multiple identical "items" in the dialog window.
But there's no context menu and I can't even doubleclick on an item to jump to the causing model element.
Is something wrong here or do I expect too much and there simply is no other option than "Recover/Clean" all issues?
Re: Project Integrity Check: No jump to element?
« Reply #1 on: October 26, 2021, 12:01:46 am »
Simply always recover/clean all issues.
There are a couple of topics on the forum that go a bit deeper in the why/how.
EAabecedarian
« Reply #2 on: October 26, 2021, 12:40:41 am »
And simply ignore the warning "This recovery tool could make substantial changes to your model"?  :-\
Btw: The new Report after Recover/Clean is identical to the one before :o
So I don't only not know where the issues are caused but also have no chance of easily getting them fixed...
Could it be that that model has just grown too big (eap file size is 76MB) for the Integrity check to work as intended?
« Reply #3 on: October 26, 2021, 12:54:21 am »
yes, ignore the CYA warning.
76MB is in fact a fairly small model, so that won't be the problem.
You might want to try to send an email to sparx support to get the errors fixed.
EAabecedarian
« Reply #4 on: October 26, 2021, 01:11:11 am »
Ok, I think I can live with it for now  :)
I'll take care to not get such confusion in my (really tiny) own models.
THX!
