Author Topic: Executable State Machine -Interpreted Simulation returns error ''not a function'  (Read 10162 times)
DaVos
Hi everyone
I am trying to simulate an executable state machine that calls an operation. The operation returns a value and it is defined on a class.
As a first step I have used the EA example CD Player.
By running the simulation on interpreted mode I got the following error
\\sim.next is not a function.\\ The simulation is running on java.
The same error I got on my simulation.
I have followed all the guidelines described on EA dynamic simulation guidelines.
Did anyone faced the same problems with dynamic simulation ?
Regarding technicalities
1. How EA defines an operation on a class ?
for example if I define the following
this.a=a
this.b=b
return a+b
Is this enough or I have to define a method based on Java ? Define public or state keywords for the method definition etc
2. How I call this operation from a class ?
I have to define an object or just a simple call will do the job ? For example this.result=add(1,2)
Any help appreciated
philchudley
I have exactly the same problem I am using EA version 15.2.1560, although a colleague has said it all works fine in EA 15.1 which I haven't tried.
I even get the same error when trying to use the examples within EAExample
Some form of reply would be very nice and appreciated.
Phil
Models are great!
philchudley
Just a follow up, I get the same "not a function" error in EA v16 beta
Phil
Models are great!
