Author Topic: V16 Beta on V15 Production Database  (Read 11993 times)
BJTim
« on: November 13, 2021, 01:54:22 am »
It's hard for me to test the use cases with V16 in a completly separated test environment.
So I'd like to use the current beta with a V15 production database.
What is the risk within this scenario?
That it needs V16 to use features of V16 is clear.
Will V15 features used by V16 be corrupted? May the database become invalid and unusable?
I know, it's not recommended, but if you want early and profound feedback, the time I may invent in special tests is limited.
Greetings from Bruchsal, Germany
Bernd  8)
Re: V16 Beta on V15 Production Database
« Reply #1 on: November 13, 2021, 10:23:20 am »
Well, like with all beta SW on a production the risk will be a corrupt database and complete data loss. Sparx will for sure not promise anything else. It's rather unlikely, so if you're a daredevil: go on. If you have a "real" production environement then you also have a "real" test environment. If not, oure juggling with hot coals. Good luck.
« Reply #2 on: November 13, 2021, 06:41:46 pm »
I would probably risk it. Just make sure you have a proper backup schedule just in case something does go wrong.
Sunshine
  • Its the results that count
« Reply #3 on: November 14, 2021, 05:56:01 am »
Probably worth checking you've got the latest schema too before using V16
https://sparxsystems.com/resources/repositories/index.html#table_script_sqlsvr
Happy to help
