Author Topic: Use Transformation script metod or standard scripting  (Read 13841 times)
steen.jensen
« on: November 23, 2021, 12:04:49 am »
Have some users using an propritary notation "Prime Arch" that is as Archimate om Steriods :o.
Now they have some issues and we Wonder how to simply transform those models  to UML and/or Archimate.
By Transformation script or  standard scripting (JavaScript).
Whats easiest method??
Re: Use Transformation script metod or standard scripting
« Reply #1 on: November 23, 2021, 12:18:52 am »
Definitely easier using a standard script.
The transformation template syntax is euh, lets say "headache-inducing" :-X
« Reply #2 on: November 23, 2021, 03:17:38 am »
Just what Geert said.
Sunshine
  • Its the results that count
« Reply #3 on: November 23, 2021, 07:57:35 am »
It really depends on your skilllset. Assuming you have your model already in Sparx EA then script is probably the easiest if you have experience programming in jscript/javascript.
Do you want to transform (keep the original and create another set of element types) or Convert (change the original elements to a new set like Archimate).
I have shared JScript to convert objects and stereotypes of elements from one modelling language to another in the forum a few times. This post was the last time I share the script but with just one element type to convert. If you do a search through my posts you'll find similar code but with more elements to convert.
This might help you kick off what you need.
https://www.sparxsystems.com/forums/smf/index.php/topic,45674.msg267977.html#msg267977
To change a number of elements types and stereotypes just add entries to the TypeConversion[] array at the top to the code
// Array of types and stereotypes to convert: Source Type, Source Stereotype, Target Type, Target Stereotype
Conversions[0] = new TypeConversion("Class", "Standard", "Class", "Archimate::Standard");
Conversions[1] = new TypeConversion("Class", "Requirement", "Class", "Archimate::Requirement");
Conversions[2] = new TypeConversion("Component", "", "Component", "Archimate::Component");
If you wanted to convert relationships as well then need to add that code.
If however programming jscript skills aren't in your skill set then an alternative which is a bit of a hack.
Open an eap file with MS Access and do a search and replace in t_object and t_connection tables to convert or write SQL script.
Happy to help
steen.jensen
« Reply #4 on: November 24, 2021, 09:56:20 am »
Thanks all of you.
Thats seems to be doable even for me  8)
