Author Topic: MDG extend stereotype  (Read 10745 times)
milan.petrak
« on: November 24, 2021, 06:44:48 am »
Hi all,
It's possible define <profile> with some how extended <stereotype> or build it as composite ?
https://www.dropbox.com/s/u9ey1lksflc9ei6/Snimka.JPG?dl=0
In my case Element<stereotype> is composite from _ElementType
Tx
Milan
Re: MDG extend stereotype
« Reply #1 on: November 24, 2021, 08:00:19 am »
Generalization from Element to _ElementType.
Extension is only from a stereotype to a UML type.
« Reply #2 on: November 24, 2021, 09:38:17 am »
The other Extensions just look strange, don't they? I thought that Extension is only from Stereotype to Metaclass? What would be an Extension from Class to Stereotype. Nothing defined in UML, I guess.
Quote from: UML 2.5 . 271
An extension is used to indicate that the properties of a metaclass are extended through a stereotype, and gives the ability to flexibly add (and later remove) stereotypes to classes.
milan.petrak
« Reply #3 on: November 28, 2021, 06:09:05 am »
I made _ElementType ... where I want to use those parameters in stereotype Element which will extend class <metaclass>
I want to try make mdg for openui ...
https://photos.app.goo.gl/fyZW6UcEu3jVcY8y5
i thing i must build it in jscript
tx
« Reply #4 on: November 28, 2021, 07:18:11 am »
Again: Extension works only from Stereotype to Metaclass. Anything else would be undefined.
