Author Topic: Assign Activity to Operations behavior  (Read 9636 times)
dgoetz
« on: November 26, 2021, 10:13:54 pm »
I try adding an activity for all operations of a class using an Add-In.
It works when the function is exited and returns to EA. The Behavior attribute contains the activity's GUID in EA.
But when I read the Behavior attribute later in the Add-In before it is exited, it is empty.
Is there any Update-Refresh trick? I tried element.Methods.Refresh(); element.Update(); and element.Refresh(); without any effect.
Dieter
EA.Package package; EA.Element element; // actually assigned in the Add-In
foreach (EA.Method method in element.Methods)
EA.Element activity = package.Elements.AddNew("Name", "Actvity"); // add new activity
method.Behavior = activity.ElementGUID;  // assign activity to methods behavior
method.StyleEx = "ShowBeh=1;";
method.Update();
string behavior = method.Behavior;  // behavior contains GUID of new activity -> OK
string behavior = method.Behavior;   // -> behavior is empty
Sparx EA V15.2.1559
Re: Assign Activity to Operations behavior
« Reply #1 on: November 26, 2021, 10:42:33 pm »
Hi Dieter,
Try saving the ID of the methods, then once you've done the .Update(), retrieve the method via the ID directly from the Repo.
When I was developing Add-Ins, I found EA would "lose its way when dealing with collection based items.  Getting it back again solved the issue.
PAolo
« Reply #2 on: November 26, 2021, 11:26:27 pm »
A rare case where you need a Refresh() on the collection between the loops.
q-
dgoetz
« Reply #3 on: November 26, 2021, 11:33:28 pm »
Hi Paolo,
thanks a lot. It works.
Dieter
foreach (EA.Method method in element.Methods) // maybe replace foreach loop by for loop also
method.Update();
        for (short idx = 0; idx < element.Methods.Count; idx++)
                EA.Method elementMethod = this.element.Methods.GetAt(idx);
                EA.Method method = EArepo.GetMethodById(elementMethod.MethodID);
