Author Topic: ArcGIS xml export has duplicate attributes - EA 16 beta  (Read 11216 times)
bizna
« on: December 03, 2021, 02:04:54 pm »
When I export my ArcGIS model to XML, it contains duplicate attributes (aka Fields in ArcGIS).  When I import this XML schema into an ArcGIS geodatabase, it creates the duplicated fields with the name plus an "_1" appended at the end of the name. I suppose I could revert back to the EA version 15.2, but I've made a bunch of progress on my model in v16.0 and would like to carry on with it.  I suppose I should log a bug report with EA, and in the meantime maybe I'll try to find a way to remove the duplicate entries in the .XML file.  If anyone knows of a better way to fix this, please let me know.
ea0921
Re: ArcGIS xml export has duplicate attributes - EA 16 beta
« Reply #1 on: March 23, 2022, 06:45:46 am »
Hi! I'm having the same problem with the 15.2.1560 version.
Have you solved this issue?
I have deleted the duplicates attributes from the XML file, but there must be a better way to fix this problem
Cheers!
hainsworth
« Reply #2 on: September 09, 2022, 04:18:02 am »
Is there any update on this issue?  I am seeing this still occur at EA16 final.
