Author Topic: EA Eclipse MDG and Eclipse Juno  (Read 5961 times)
philchudley
« on: April 04, 2013, 07:07:45 pm »
Have installed the latest version of Eclipse (i.e. Juno Service Release 2) and installed the latest version of the EA Eclipse MDG integration.
All installs fine and I do see an Enterprise Architect menu option in Eclipse Juno.
However upon selecting any one of the two options from the Enterprise Architect menu in Eclipse Juno, the following Eclipse error appears
[highlight]The chosen operation is not currently available[/highlight]
Any ideas?
Cheers
Phil
Models are great!
SomersetGraham
Re: EA Eclipse MDG and Eclipse Juno
« Reply #1 on: April 04, 2013, 07:24:20 pm »
Hi
I am using Eclipse Juno with the EA Eclipse MDG successfully
some questions -
Did you uninstall the MDG(via control panel) before installing Eclipse ?
Do you have the lasted Java installation ?
Did you ensure that when installing the MDG you correctly set the the path to the Eclipse exe ?
Cheers
Using V12
philchudley
« Reply #2 on: April 04, 2013, 08:16:37 pm »
Thanks for your reply
I can confirm that I have the latest version of Java
Yes the path to Eclipse is correct and Eclipse can be launched from EA
However I did install the MDG after I had installed Eclipse, maybe this is the issue?
Models are great!
SomersetGraham
« Reply #3 on: April 04, 2013, 08:42:16 pm »
That is the correct order.
I would uninstall the MDG and Eclipse and then try re installing, if that fails you will have to contact Sparx support
Using V12
Aaron B
« Reply #4 on: April 05, 2013, 10:50:25 am »
Can you please confirm whether you are running the 32-bit or 64-bit version of Eclipse?  MDG Integration is not compatible with the 64-bit version of Eclipse and is a known cause of the "The chosen operation is not currently available" error message.
If you are using the 64-bit version of Eclipse - please download and install the 32-bit version of Eclipse, then re-install MDG Integration.
philchudley
« Reply #5 on: April 05, 2013, 06:45:47 pm »
Thanks all for your replies, and Aaron you hit the solution. I am indeed running 64bit Eclipse
Will change for the 32bit version as advised
Thanks again
Models are great!
