Author Topic: MDG ShapeScript render class as a use case  (Read 4874 times)
Guillaume
    • www.umlchannel.com
« on: January 06, 2022, 10:34:51 pm »
I have a stereotyped class that I need to display as a Use Case (ellipse) based on a tagged value.
I can't get the element name to be printed in the middle.
I ran a test without the Tagged value condition which works:
shape main{
h_align = "center";
v_align = "center";
ellipse (0, 0, 100, 100);
print("#name#");
With the following ShapeScript, I'm getting the following error: Unexpected symbol h_align
shape main{
      if (HasTag('UC','true'))
h_align = "center";
v_align = "center";
print("#name#");
else
DrawNativeShape();
I also tried the following but the label is still rendered in the top left corner.
shape main{
addsubshape("uclabel");
shape uclabel{
setorigin("CENTER",0,0);
print("#name#");
else
DrawNativeShape();
Guillaume
Re: MDG ShapeScript render class as a use case
« Reply #1 on: January 07, 2022, 12:19:58 am »
Hi Guillaume,
Try using shape Label  as in:
shape Label   //v2.2 29-Nov-2021   //@CENTER
   if(hasproperty("rectanglenotation","0"))   //label only in Icon Form
      print ("#Name#");
}      //Shape: Label   //@CENTER
[code]
« Reply #2 on: January 07, 2022, 12:23:15 am »
   h_align = "center";
   v_align = "center";
are only valid at the beginning of a (sub)shape
If you are happy with your main shape, you should be able to put that into a subshape, and add the subshape conditionally.
So something like (without testing)
shape main{
addSubShape("useCase", 100, 100);
else
DrawNativeShape();
shape useCase
h_align = "center";
v_align = "center";
print("#name#");
Guillaume
« Reply #3 on: January 07, 2022, 01:14:08 am »
Hi Geert and Paolo,
Thank you for your answers.
I used Geert's suggestion which works perfectly   :D
Cheers
Guillaume
