Author Topic: EA 15.2 - Component Diagram - Cannot 'Convert to Instance' on some Components  (Read 21477 times)
Janhn_fnb_za
I copied a (template) Component Diagram and now want to convert components on the copied diagram to instances.
EA isn't allowing me to do it on some components (but works on others) - I only get
Parent
Multiplicity
Convert Linked Element to Local Copy
under the Advanced menu.
Jan
You'll have to try and figure out what makes some components different from others I guess
Might be nesting, might be location in the model, locking, stereotypes, ...
Janhn_fnb_za
Hi Geert
Thanks for your reply.
From some cursory examination, it seems all the components I'm having issues with has Provided Interface elements attached to them.
For components that don't, there's no issue and the option is available.
Is this expected? It seems quite counter-intuitive.
Yes, I can reproduce that. You can't convert it to an instance if it has embedded elements.
I think embedded elements are not allowed on objects, so converting it to an instance would result in an invalid situation.
This may be because EA creates Objects (that is runtime instances of Classes) when you "Convert to instance".  I do believe that this is correct for metatypes that aren't pure classes.  I think I covered this in my What IS an Instance post.  We do not use Objects at all for Instances.
Object is a metaclass from ancient 1.5. It's InstanceSpecification now. For the well-know compatibility reasons Sparx prefers to stay with Object. There's some chat with Eve about that topic.
Hi Jan,
It sounds like a frustrating issue. Have you checked if those components have any specific constraints or properties that might be preventing the conversion? Sometimes, certain settings or dependencies can cause this problem.
Best,
spam website
Ah, some very sneaky spam, setting the size to 1 so it looks like a line instead of an url.
Actually the font color is just a light one. Anyhow, I wonder who will click a link that is not visible? Seems spamers are just idiots - proving that this hypothesis is true.
