Author Topic: v16β - new .EAPX schema?  (Read 4765 times)
« on: January 13, 2022, 03:29:06 pm »
We have a number of .eapx files that are generating a
"DAO.Database [0x00000d0e]
Invalid Memo, OLE, or Hyperlink Object in subquery 't_object.PDATA2'"
error under v16β (both versions).
Searching the Net doesn't bring up anything as to what the error means.
We have (in the past) "hijacked" t_object.PDATA2 and this has caused NO problems up to and including v15.2.
Since null is a valid value for PDATA2 we ran a test making the column null for all objects.  The problem persists and the upshot is that NO diagrams show ANY objects (whether PDATA2 is null or not).
Did we miss a schema change between v15 and v16β?  If not, what can this error mean?  Anyone else seeing this?
TIA,
BTW: in the past, we have had error messages from EA that are spurious - that is the error is NOT what is claimed.  Unfortunately, as in this case, the actual problem can't be determined since the message provides no direction for the investigation.
Sunshine
  • Its the results that count
Re: v16β - new .EAPX schema?
« Reply #1 on: January 13, 2022, 05:53:39 pm »
Not experienced that exact problem but I am finding that some eapx files open okay and some I get DAO.Engine [0x80004005] cannot open a database created with a previous version of the application.
Haven't had time to look into it.
All the eapx files open okay with V15.2.
Happy to help
« Reply #2 on: January 13, 2022, 07:55:42 pm »
Thanks, Sunshine,
Good to know we're not alone!
