Author Topic: Autocolor legends used flexibly  (Read 6989 times)
DeBAAT
« on: February 03, 2022, 09:35:33 pm »
The autocolor function of Legends is very useful to show how different elements share the same value, e.g. a status like "Open" or "Closed".
The way to define the colors is to define the color to show for each of the possible values.
This works fine with predefined values like you can use with Status.
However, this works less fine when the value of the related attribute is not easily determined beforehand.
An example of my work now is the name of the ContactPerson as defined for an application.
As soon as the spelling of a name changes or a new value is added, I need to change the definition of the legend.
It would help me very much if it would be possible to have real autocolor as generated by the system.
The way it could work is to pre-define a list of possible colors, determine the list of possible values (dynamically with a query from the database) and assign each value a color from the predefined list, based on the order in the generated list.
Any suggestions on how I could make this myself?
Re: Autocolor legends used flexibly
« Reply #1 on: February 03, 2022, 10:08:42 pm »
You could make a script that changes the appearance of the diagram like that if you wanted.
DeBAAT
« Reply #2 on: July 31, 2023, 02:50:35 am »
At last found some time to work on the script.
It resulted in the code at the end of this post.
The basic working is a JavaScript on a Diagram.
With the selected diagram, it processes all elements on the diagram.
For every Legend element, it determines the TaggedValue that is used for the auto coloring of elements.
With the TaggedValue Property found, it looks for all distinct values present in the t_objectproperties table.
Each value found is assigned a separate color, choosen from a predefined list of colors.
After processing, the diagram is reloaded.
For now, I have some issues I'm still struggling with:
  • Using the Repository.Execute() method works for updating the values in the database. However, I can't seem to get a result from the execution. Is there a way to tell whether the update was successful?
  • I use a predefined list of colors to assign to the different TaggedValues but I'm not quite fond of these colors. Any suggestions on where to find a better list of colors to assign?
Any suggestion for improvement of the code is also always welcome.
The code itself:
!INC Local Scripts.EAConstants-JavaScript
 * This code has been included from the default Diagram Script template.
 * For all LegendElements on the selected diagram:
 *   If TaggedValue filter
 *      Find all TaggedValues for this Value
 *      Update t_xref list of properties for this legend
 *   Refresh Diagram
 * Script Name: RefreshDynamicLegend
 * Author:      J de Baat
 * Purpose:     Refresh the set of color definitions of all legend elements supporting all values occuring on the selected diagram
 * Date:        27-07-2023
 * A list of colors to use for generating the list of legend values
 * Hexadecimal to Decimal converter via https://www.rapidtables.com/convert/number/hex-to-decimal.html
var legendColors =[ "1029550", // #0FB5AE
            "4212426", // #4046CA
            "16155921", // #F68511
            "14564738", // #DE3D82
            "8291578", // #7E84FA
            "7528554", // #72E06A
            "1342195", // #147AF3
            "7546579", // #7326D3
            "15255040", // #E8C600
            "13327616", // #CB5D00
            "36701", // #008F5D
            "12380465", // #BCE931
            "0" // #black
 * Test whether an element is a Legend
function ElementIsLegend( theElement )
// Cast theElement to EA.Element so we get intellisense
var inputElement as EA.Element;
inputElement = theElement;
return ( (inputElement.ObjectType == 4) && (inputElement.Subtype == 76) );
 * Get the filter value for the LegendElement
function GetLegendFilter( theElement )
// Find the TaggedValue in the string of format "*LegendTypeObj=Filter=" + "TaggedValue." + strLegendTaggedValue + ":;*"
var strLegendTaggedValue01 = inputElement.StyleEx.split("LegendTypeObj=Filter=");
var strLegendTaggedValue02 = strLegendTaggedValue01[1].split(":;");
var strLegendTaggedValue03 = strLegendTaggedValue02[0].split(".");
if ( strLegendTaggedValue03[0] == "TaggedValue" )
// Check for strLegendTaggedValue to be of format strLegendValue + ":AppliesTo=*"
var strLegendTaggedValue04 = strLegendTaggedValue03[1].split(":AppliesTo=");
return strLegendTaggedValue04[0];
return false;
 * Get all values for theTaggedValueProperty from the t_objectproperties table
function GetLegendTaggedValuesForProperty( theTaggedValueProperty )
// Get all the TaggedValues registered for theTaggedValueProperty
var strSQLQuery = "select distinct t_objectproperties.Value as TaggedValues from t_objectproperties"
                      + " where t_objectproperties.Property = '" + theTaggedValueProperty + "'"
                      + " order by t_objectproperties.Value";
var sqlResponse = Repository.SQLQuery( strSQLQuery );
// Convert the sqlResponse from XML to an array of TaggedValues
var arrResponse = convertXMLtoTagNameArray( sqlResponse, "TaggedValues" );
return arrResponse;
 * Extract an array from the XML resultset of an SQLQuery based on the xmlTagName
function convertXMLtoTagNameArray( xmlString, xmlTagName )
var xmlDOM = new COMObject( "MSXML2.DOMDocument" );
xmlDOM.validateOnParse = false;
xmlDOM.async = false;
if ( xmlDOM.loadXML( xmlString ) ){
var nodeList = xmlDOM.documentElement.selectNodes( '//' + xmlTagName );
if ( nodeList.length > 0 ) {
return nodeList;
return false;
 * Update the Description value for the LegendElement in the t_xref table
function updateLegendElementXRef( theElement, theLegendDescription )
var strSQLQuery = "update t_xref set Description = '" + theLegendDescription + "'"
                      + " where Name = 'CustomProperties'"
                      + " and Type = 'element property'"
                      + " and Client = '" + inputElement.ElementGUID + "'";
var sqlResponse = Repository.Execute( strSQLQuery );
return true;
// TODO: Check sqlResponse as result of Repository.Execute
//Session.Output("strSQLQuery ==> Resulted in: " + sqlResponse );
//return sqlResponse;
 * Make a new property string for the theValueName and theValueIndex
function getLegendPropString( theValueName, theValueIndex )
var strPropOutput = "";
strPropOutput += "@PROP=";
strPropOutput += "@NAME=";
strPropOutput += theValueName;
strPropOutput += "@ENDNAME;";
strPropOutput += "@TYPE=LEGEND_OBJECTSTYLE@ENDTYPE;";
strPropOutput += "@VALU=#Back_Ground_Color#=";
strPropOutput += legendColors[theValueIndex % legendColors.length ];
strPropOutput += ";";
strPropOutput += "#Pen_Color#=0;";
strPropOutput += "#Pen_Size#=1;";
strPropOutput += "#Legend_Type#=LEGEND_OBJECTSTYLE;";
strPropOutput += "@ENDVALU;";
strPropOutput += "@PRMT=";
strPropOutput += theValueIndex;
strPropOutput += "@ENDPRMT;";
strPropOutput += "@ENDPROP;";
return strPropOutput;
 * Make a new property string for theLegendName and theLegendTitle
function getLegendStyleSetting( theLegendName, theLegendTitle )
strPropOutput += theLegendName;
strPropOutput += "@TYPE=LEGEND_STYLE_SETTINGS@ENDTYPE;";
strPropOutput += "@VALU=#TITLE#=";
strPropOutput += theLegendTitle;
 * Process a LegendElement provided as parameter
function ProcessLegendElement( theElement )
currentElement = theElement;
// Check whether the currentElement is a Legend
if ( ElementIsLegend( currentElement ) )
var strLegendFilterProperty = "";
var strLegendTaggedValues = "";
var strLegendProperty = "";
strLegendFilterProperty = GetLegendFilter( currentElement );
strLegendTaggedValues = GetLegendTaggedValuesForProperty( strLegendFilterProperty );
// Process the strLegendTaggedValues found
if ( strLegendTaggedValues.length > 0 ) {
// Add all getLegendPropString found for all strLegendTaggedValues
for ( var i = 0 ; i < strLegendTaggedValues.length ; i++ ) {
strLegendProperty += getLegendPropString( strLegendTaggedValues.item(i).text, i );
// Add the getLegendStyleSetting found
strLegendProperty += getLegendStyleSetting( currentElement.Name, currentElement.Name );
// Refresh the currentElement and Update the currentDiagram to reflect the changes
var boolResult = updateLegendElementXRef( currentElement, strLegendProperty );
if ( boolResult ) {
Session.Output("Legend(" + currentElement.Name + ") UPDATED successfully!!!" );
} else {
Session.Output("Legend(" + currentElement.Name + ") update NOT successful!!!" );
} else {
Session.Output("Legend(" + currentElement.Name + ") found NO valid strLegendTaggedValues!!!" );
 * Diagram Script main function
function RefreshDynamicLegendScript()
// Get a reference to the current diagram
var currentDiagram as EA.Diagram;
currentDiagram = Repository.GetCurrentDiagram();
Session.Output("+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++" );
if ( currentDiagram != null )
Session.Output("Selected Diagram(DiagramID: " + currentDiagram.DiagramID + ") Name= " + currentDiagram.Name );
// Get a reference to any selected connector/objects
var diagramObjects as EA.Collection;
var currentElement as EA.Element;
diagramObjects = currentDiagram.DiagramObjects;
// Check whether this diagram has any objects in it
if ( diagramObjects.Count > 0 )
Session.Output("Selected diagramObjects.Count: " + diagramObjects.Count );
// One or more diagram objects are selected
for ( var i = 0 ; i < diagramObjects.Count ; i++ )
// Process the currentDiagramElement
var currentDiagramElement as EA.Element;
currentDiagramElement = diagramObjects.GetAt( i );
currentElement = Repository.GetElementByID( currentDiagramElement.ElementID );
// Process the currentElement when it is a Legend
ProcessLegendElement( currentElement );
// Reload diagram when all processing is done
Repository.ReloadDiagram( currentDiagram.DiagramID );
else
// No objects on this diagram
Session.Output("No objects on this diagram" );
else
Session.Prompt( "This script requires a diagram to be visible.", promptOK)
Session.Output("===========================================================================================" );
RefreshDynamicLegendScript();
« Last Edit: July 31, 2023, 04:27:23 pm by DeBAAT »
« Reply #3 on: July 31, 2023, 05:38:39 am »
Well, if the Execute fails it's due to a syntax error and you get a pop-up. Else it succeeds. If you don't trust that: run a query. But that's, sorry, ridiculous. If it includes some WHERE you're better off to think first...
