Author Topic: Connector ShapeScript to change line colour (including line ends)  (Read 4226 times)
Modesto Vega
We have he following connector ShapeScript to change the line colour based on a tag value. The script changes the colour of the line but not of the line ends - e.g., arrowheads.
What are we missing?
shape main
noShadow=true;
SetLineStyle("SOLID");
if(HasTag("Status","Live"))
SetPenColor(102,204,102);
else if(HasTag("Status","In Development"))
SetPenColor(0,0,255);
else if(HasTag("Status","Deprecated"))
SetPenColor(255,195,0);
else if(HasTag("Status","Decommissioned"))
SetPenColor(199,0,57);
MoveTo(0,0);
LineTo(100,0);
label middlebottomlabel
print("");
« Last Edit: February 03, 2022, 09:53:40 pm by Modesto Vega »
Re: Connector ShapeScript to change line colour (including line ends)
« Reply #1 on: February 03, 2022, 09:59:45 pm »
Nothing. That's a bug. I did not report it but accepted it since it won't be fixed anyway :-/
« Reply #2 on: February 03, 2022, 10:13:01 pm »
You are missing shape source and shape target in your shapescript.
These define the line ends.
« Reply #3 on: February 03, 2022, 10:34:35 pm »
Well, they ignore the color as well. That's what I said about the bug...
q-
Modesto Vega
« Reply #4 on: February 04, 2022, 12:45:36 am »
Actually, I think Geert is correct. The ShapeScript below renders both ends correctly (it is based largely in of Geert's archimate shapescripts.
shape main
noShadow=true;
MoveTo(0,0);
LineTo(100,0);
shape source
SetFillColor(102,204,102);
SetFillColor(0,0,255);
SetFillColor(255,195,0);
SetFillColor(199,0,57);
ellipse(-4,-4,4,4);
shape target
startpath();
moveto(0,0);
lineto(10,4);
lineto(10,-4);
lineto(0,0);
endpath();
fillandstrokepath();
print("");
So I guess if I do
startpath();
moveto(0,0);
lineto(10,4);
lineto(10,-4);
endpath();
I will mange to render an open arrowhead of the right colour.
« Reply #5 on: February 04, 2022, 02:59:36 am »
Well, if you fill  a path it will not be open but filled.
Modesto Vega
« Reply #6 on: February 04, 2022, 03:12:34 am »
Indeed, trying to see if strokepath() produces the desired result.
