Author Topic: Case sensitive stereotypes  (Read 5395 times)
« on: February 04, 2022, 02:54:52 am »
Although the UML spec tells us that the stereotypes are not case sensitive, EA wants the correct case when you define entries in your toolbox. E.g. if you add "UML::association" it will show the guillements only and not create a connector. Only when you type "UML::Association" it will create a correct entry. Same with any other entry here (like Dependency etc.).
Could that be fixed? (I guess not, but at least it's noted here.)
Re: Case sensitive stereotypes
« Reply #1 on: February 04, 2022, 08:53:28 am »
Citation needed. I'll agree that EA treats stereotype names as case insensitive, but I can't see anything in UML saying that they should be.
Unrelated to stereotypes. In this case you have a UML metaclass.
« Reply #2 on: February 04, 2022, 09:08:06 am »
Uhm, yes. You are right about the metaclass. But this seems to be only wrong for relations. I had both UML::class and Class working. I also remember some quirks with that for other metaclasses.
I come back with the citation. I had this in an answer somewhere on StackOverflow.
P.S. p. 260:
Normally a Stereotypes name starts with an upper-case letter, to follow the convention for naming Classes. However Profiles may use different conventions. Matching between the names of Stereotype definitions and applications is case- insensitive, ...
(I got this em-dash bug here again asking to report it to whom ever. I just copy/pasted from the PDF. Removed a "suspicious" apostrophe)
« Last Edit: February 04, 2022, 09:11:23 am by qwerty »
