Author Topic: Frustrating "Dashboard Style" layout cannot be undone  (Read 22134 times)
ItsPronouncedZed
« on: February 05, 2022, 03:51:22 am »
Having spent a solid hour on a complex diagram, I hit the "Dashboard Style" diagram dropdown from the properties portal by mistake. Well, that didn't turn out well...  :(
Surely there must be a way to undo, or at least warn the user that the layout change cannot be undone.
https://sparxsystems.com/enterprise_architect_user_guide/16.0/model_publishing/using_dashboard_styles.html
Notes
The styles as a group are effectively permanent; once a diagram has had a style applied, you cannot change the layout other than by applying another style, and you cannot restore the original un-styled layout
Re: Frustrating "Dashboard Style" layout cannot be undone
« Reply #1 on: February 05, 2022, 04:32:22 am »
Pretty scary indeed.
I did manage to undo the changes by setting the dashboard style to none, and then closing and re-opening the diagram (without saving)
« Reply #2 on: February 05, 2022, 07:45:34 am »
Same when using Add Related and have the (default) Layout Diagram not unchecked. Lucky me that happend (happens) only for diagrams with few elements.
