Author Topic: EA 15.2 Wireframing combobox - can NOT change the text of the items  (Read 14744 times)
Erni
Hello I am new in here so pls forgive me if there is already explanation/fix/workaround or I am doing something wrong.
According to: https://sparxsystems.com/enterprise_architect_user_guide/15.2/model_domains/dialog_wireframe_toolbox.html
Controls => Item => Combo Box
You can change the text of the items, and add or remove items in the list, by editing the 'Values:' list in the Tagged Value notes
I can not do that :/
There is no 'Values:' list in the Tagged Value notes
I am using EA 15.2 trial
Please help!
Re: EA 15.2 Wireframing combobox - can NOT change the text of the items
« Reply #1 on: February 09, 2022, 08:12:25 am »
Profiles like wireframing get their own tab on that dialog. Look down from your arrow.
« Reply #2 on: February 09, 2022, 10:02:45 am »
interesting. Would that be possible with a profile? (I guess not unless you have your profile developer sitting somewhere in Sparx' premises?)
« Reply #3 on: February 10, 2022, 08:17:53 am »
Yes, that dialog hasn't been changed. It still has the old behavior.
Erni
« Reply #4 on: February 10, 2022, 05:46:55 pm »
And how can I do that? When I click a little triangle "▷ Combobox" it doesn't expand and there is nothing happening.
Can you please check on this and explain more?
Maybe this is only EA trial edition issue/bug?
The wiereframing tab works like that:
« Last Edit: February 10, 2022, 05:54:08 pm by Erni »
« Reply #5 on: February 10, 2022, 05:55:09 pm »
On the bottom of that dialog there is a Tab that reads WireFraming. The tags you are looking for are there
Erni
« Reply #6 on: February 10, 2022, 07:14:31 pm »
Thanks for you answer but sorry I don't get it :( - can you provide a screenshot of what you talk about with your custom list values?
« Reply #7 on: February 10, 2022, 09:15:01 pm »
Pictures her are a PITA. Just read what Geert said. Follow the red arrow in reverse direction keeping them a bit to the left. Right left of "Tags" you find "Wireframing".
« Reply #8 on: February 10, 2022, 09:35:05 pm »
Erni
« Reply #9 on: February 16, 2022, 04:48:28 pm »
« Reply #10 on: February 16, 2022, 04:56:18 pm »
Guys but there is nothing I can do to change combobox values :|
Can you do that?
Look: https://lh3.googleusercontent.com/gnthWxbUWEesG0cBuEfk9tHuDpFZR3oNUZn9fhnwtCcZzVvuTvqi2zCl4rZCY3Er935g896YbMKQj9vz6GQE=w1920-h937-rw
Your link is not valid. Try posting an image on imgur.com
Erni
« Reply #11 on: March 14, 2022, 09:56:01 pm »
Hi sorry for delayed answer I was on vacations for few weeks.
Here is the link to the screen:
https://imgur.com/a/ZXRnIQo
« Reply #12 on: March 15, 2022, 07:53:31 am »
See the row of icons above the red arrow: click the 4th from the left.
Erni
« Reply #13 on: March 28, 2022, 05:32:20 pm »
THANK YOU VERY MUCH!!!
It solved the case.
