Author Topic: MDG: add relationships between built-in elements  (Read 4648 times)
Guillaume
    • www.umlchannel.com
« on: February 11, 2022, 10:23:23 pm »
I set up a custom MDG with stereotyped SysML blocks and ports. For the internal block diagram, standard SysML parts will be used (not stereotyped) and I would like to create stereotyped connectors between them.
EA Strict Connector Syntax preference has been enabled to restrict the allowed connectors as per the MDG definition (using metaconstraints ..)
When I try to create a stereotyped connector between parts, I get the following error: "invalid combination of source and target types for this connector type".
If I disable the  Strict Connector Syntax, it works.
In the MDG, I added the Part (Property) metaclass and created a "stereotyped relationship" link with stereotype tagged value = "customConnect". I also used the metaconstraint links between customConnect stereotype and the Part metaclass.
Is there a way to extend the allowed connectors on native element types such as Parts ?
Guillaume
Re: MDG: add relationships between built-in elements
« Reply #1 on: February 11, 2022, 10:35:38 pm »
I'm not sure if stereotyped relationship works for native elements, but I believe it works when you make metaconstraints with umlrole=client/supplier for your connector stereotype.
Guillaume
« Reply #2 on: February 12, 2022, 12:12:19 am »
Hi Geert,
Thanks for the advice.
Even though it didn't work, I managed to find the solution: I tend to put metaclass elements within a profile subpackage. Having moved it to the root package, it worked :)
Guillaume
« Reply #3 on: February 12, 2022, 12:02:17 pm »
Hi Geert,
Hi Guillaume,
Can you explain EXACTLY what you mean by your solution?  I have a similar issue and this may solve my problem too.  But it's not clear I'm in the same place you were before the fix.
