Author Topic: Fork and Join transition  (Read 3277 times)
Seth
« on: February 18, 2022, 12:42:49 am »
hello all, i'm having trouble with the simulation of a state machine. in short i have 2 triggers that join from different  states, but once the sim gets to the join, it doesn't follow the transition path out of the join to the penultimate and then final state...
any ideas?
Re: Fork and Join transition
« Reply #1 on: February 18, 2022, 02:04:22 am »
A join waits for all incoming transitions before it continues.
You might need to use a merge instead of a join if that is not what you intended.
Seth
« Reply #2 on: February 18, 2022, 09:29:20 pm »
hi Geert, thanks for that, that indeed was the issue then.
