Author Topic: Deleting wrong record in t_seclocks  (Read 5493 times)
wzr
« on: February 19, 2022, 10:28:42 pm »
when I'm transfering our DB from MSSQL-Server to a local eapx file i'm always getting an error message, saying that there is an entry in t_seclocks with an empty entity id. The transfer is still completing successfully, but the message annoying.
The result for the following query is exactly one row
SELECT *
from t_seclocks
where t_seclocks.EntityID = ''
Since this entry doesnt make any sense to me at all, I'm thinking of deleting this row by using the API:
Repository.Execute("DELETE from t_seclocks where t_seclocks.EntityID = '' ")
Do you see a chance that this will harm our model in any way?
Re: Deleting wrong record in t_seclocks
« Reply #1 on: February 20, 2022, 12:28:12 am »
You should probably rather run a consitency check to do that for you.
wzr
« Reply #2 on: February 21, 2022, 08:43:22 pm »
What consistency check do you mean and how to run it?
Configure -> Model -> Integrity -> Project Integrity doesn't report this point.
Thank you!
wivel
  • Driven by Models
« Reply #3 on: February 22, 2022, 03:49:09 am »
It seems to me that Consistensy Check does more behind the scenes, than what it reports, so you might be in luck, that the t_seclocks will be fixed anyway. I would try that out before deleting anything directly in the database.
That being said, Entity_ID should never be empty, so something is not right. If Consistency doesn't fix it, I would:
1. Backup the database using e.g. SQL Server Management Studio (its really fast)
2. Delete the t_seclocks row in error
3. Export again to an EAP(X) file
If something breaks, you can always roll back the database again.
Henrik
« Reply #4 on: February 22, 2022, 04:30:41 am »
Well, as he said. You could as well run a repository.exececute("DELETE FROM ....") to get rid of the records. Given you have the backup in any case...
« Reply #5 on: February 22, 2022, 09:17:38 am »
What gives you that belief?
The 'Report Only' action does not modify the database in any way.
The 'Recover/Clean' action only performs the 'Proposed Action' for each item from the report.
wivel
  • Driven by Models
« Reply #6 on: February 22, 2022, 09:21:04 pm »
Hi Eve
Could that my not so reliable memory that is at play now. Years back on EA 6 or 7, i seem to recall we had an issue with not being able to Tagged Values on an element, that got fixed by doing a Consistency Check, even when the report said no errors.
It is a long time ago, so again, could be I'm wrong.
Henrik
« Reply #7 on: February 22, 2022, 09:25:11 pm »
In any case the consistency check only puts out black smoke. None of the messages is really helpful to the user. There should be a log with details and possible explanations for the cause of the errors.
Just dreaming...
