Author Topic: v16RC - Extension relationship between Stereotype and Metaclass in QuickLinker  (Read 4405 times)
Under versions prior to v16, one could use the toolbox to create the Extension relationship between a Stereotype and its Metaclass.  However, this wasn't available in the QuickLinker.  We tried to create our own QuickLinker addition to do the same, but it would only work sporadically.  Under v16RC, the QuickLinker now has this relationship available.  It seems to work even with our MDG disabled, but given the magical way EA works, we can't be sure.
Can anyone confirm that it is now available in Standard EA v16RC and not some manifestation of our MDG?
TIA,
I just tested this in v15.2.1559 and there the relation is available in the quicklink.
I just tested this in v15.2.1559 and there the relation is available in the QuickLinker.
Thanks, Geert,
Even with our MDG disabled (checkbox unmarked in Manage Tech[1]), under v15.2 there's no QuickLinker entry.  Any ideas?
[1] I even removed the MDG XML file - still no go.
Hmm, not sure what else it could be dependent on. Perspectives maybe?
I tested on an SQL server repository if that makes a difference.
Works under v16RC with, presumably the same perspectives.
Oh well, to cite q.
