Author Topic: SQL Query Using Firebird  (Read 7640 times)
philchudley
« on: March 02, 2022, 03:46:47 am »
Hi All
I personally do not use Firebird as an EA repository, but I have a client who does, and I have run into a SQL Query problem.
Using a SQL query like the one shown below:
SELECT t_object.Name
FROM   t_object, t_objectproperties
WHERE  t_object.Object_ID = t_objectproperties.Object_ID
AND    t_objectproperties.Property = 'Publish?'
AND    t_objectproperties.Value    = 'Yes'
Fails since Value is a reserved word, but certainly is the column name.
Value is highlighted in Blue in the SQL Scratch Pad but works in other repository formats, so how do you use the t_objectproperties.Value column in SQL queries for Firebird?
Phil
Models are great!
Re: SQL Query Using Firebird
« Reply #1 on: March 02, 2022, 04:22:56 am »
Phil,
You have to escape the keywork in that case.
For SQL Server or Access that is done using the square brackets.
In Firebird it seems to double quotes
https://stackoverflow.com/questions/1800841/using-reserved-word-timestamp-as-a-field-name-firebird-2-5
AND    t_objectproperties."Value"    = 'Yes'
philchudley
« Reply #2 on: March 02, 2022, 08:25:51 pm »
Thanks Geert much appreciated
All the best
Phil
Models are great!
Richard Freggi
« Reply #3 on: March 04, 2022, 01:10:16 pm »
I use square brackets to escape Firebird reserved words, works for me
