Author Topic: GetCurrentDiagram() returns null  (Read 3032 times)
aljazjelen
« on: March 02, 2022, 04:03:39 am »
Hi to whoever reading this :)
I have a following code:
// Main
var rep as EA.Repository;
rep = Repository;
var diag as EA.Diagram;
diag = rep.GetCurrentDiagram();
if (diag != null){
Session.Output(diag.type);
I cannot get the "GetCurrentDiagram()" function returning anything. It always returns null (the if statement above in the code is skipped).
Anyone knows why?
Additional info:
EA v13
Selected diagram in tree
clicked on the diagram in the viewport
Re: GetCurrentDiagram() returns null
« Reply #1 on: March 02, 2022, 04:20:15 am »
The current diagram returns the diagram in the main view.
It returns null if you don't have a diagram in the active tab in the main view (there could be a script, the one you are debugging, or the database builder, or...)
I think it worked the same way back in the v13 days.
« Reply #2 on: March 02, 2022, 08:21:21 am »
To make it even more complex, you can drag a script editor out of the main view. If you're using that it will still by the active window and the current diagram will still be null.
I think it's been the same since the v4 days.
