Author Topic: Python COM AddNew Class and Image  (Read 27450 times)
FSXManu
« on: March 02, 2022, 07:36:33 pm »
Hi
I'm pretty new to this so sorry if this is a "duh, it's so easy" question :D
So I work with Python 3.8 and I get the COM Object of my repo and now I need to search for a specific package and see if a specific class already exists. If it exists I need to create an Image/png object which relates to that class.
If the class does not exist I need to create it and then attach the png/Image object.
My biggest problem is how can I create an Image with the AddNew method for the COM Object?
Could anyone help me?
Thx
Manuel
Re: Python COM AddNew Class and Image
« Reply #1 on: March 02, 2022, 07:39:31 pm »
What exactly do you mean by "create Image/png object"?
Can you describe what you do manually to create that in EA?
« Reply #2 on: March 02, 2022, 10:12:50 pm »
The image is (most likely) set somewhere in the diagramObject for the element. Most likely somewhere in the styleEx. Would need to look after that...
FSXManu
« Reply #3 on: March 07, 2022, 07:13:44 pm »
Sorry I shoul've clarified it a bit better. It should look like in the screenshot below:
So the structure in EA would look something like this:
Packacke
--Class
----StateMachine
------Artifact Image (this is the png image)
I especially struggle with the AddNew method because I can't pass the Image correctly
« Reply #4 on: March 07, 2022, 07:32:04 pm »
An image can never be an element.
« Reply #5 on: March 07, 2022, 07:49:40 pm »
Packacke
--Class
----StateMachine
You haven't actually answerred the question but only described the end result somewhat.
The reason I'm asking is because you'll have to replicate the manual steps using the API.
I'm guessing you'll have to create an artifact, add an image to the image library, and then link the image to the artifact, but it all depends on what you actually do to ge the desired end result.
« Last Edit: March 07, 2022, 09:45:49 pm by Geert Bellekens »
FSXManu
« Reply #6 on: March 07, 2022, 07:51:21 pm »
Ah okay. Sorry did some digging I think it's like Class->SubElement->Statechart/Diagram->image artifact
Does that make more sense?
FSXManu
« Reply #7 on: March 07, 2022, 09:12:12 pm »
I found a thread from 2014 in which you answered with the steps one needs to do.
I wonder if you ever did it since then or tested it. Sorry I'm completely new to this.
https://www.sparxsystems.com/forums/smf/index.php?topic=5373.0
FSXManu
« Reply #8 on: March 09, 2022, 07:45:10 pm »
Packacke
--Class
----StateMachine
Hi again
Yes So what I do in EA itself is open an item of type StateMachine and then in the Toolbox I drag an "Image Asset" into it and select my local png file. So this is what I need to do via the api I'm just not sure how/I haven't figured it out yet
FSXManu
« Reply #9 on: March 09, 2022, 08:29:03 pm »
Hi again
FSXManu
OK, so that is your next step then.
Create an element of type "Image Asset" in the package or element that owns the diagram you are working on.
Creating elements in done by using AddNew("myName", "EAUML::Image") on the .Elements collection of the owner. (could be a package or an element, depending on where your diagram is located)
Then you have to figure out how to import the actual image. The API won't help us there, so you'll have to figure out how to do it directly in the database
EA stores the image of your image asset in the table t_document
select d.* from t_object o
inner join t_document d on d.ElementID = o.ea_guid
where o.ea_guid = '{D15B1DD6-A86B-405c-ACFD-6B040386DBEE}'
by replacing the GUID above by the GUID of your image asset you'll find the record you'll need to recreate.
The difficult part will be to somehow fill in the bincontent with an SQL Query
This might depend on the actual database you are using, so you'll have to do a bit of research.
Here's a Stackoverflow question regarding this for SQL Server: https://stackoverflow.com/questions/1120689/how-can-i-insert-binary-file-data-into-a-binary-sql-field-using-a-simple-insert
The last thing you might want to do is put the image asset on your diagram.
That can be done by adding a diagramObject to the diagram.DiagramObject collection and setting the ElementID to point to your new image asset element.
« Last Edit: March 09, 2022, 08:53:29 pm by Geert Bellekens »
« Reply #10 on: March 09, 2022, 08:44:44 pm »
Image assets did not exist in 2014. So my answer referred to "normal images" handled differently. Go with Geerts answer.
FSXManu
« Reply #11 on: March 09, 2022, 11:18:17 pm »
Thank you for your help yeah I was able to use the AddNew method. Now I'm trying to insert the image into the documents table.
I read about the Execute() method which is undocumented but it would help. Problem is I always get the error "Execute() takes from 1 to 2 positional arguments but 3 were given"
My line which gives me that error:
repo.Execute("INSERT INTO T_DOCUMENT (BINCONTENT) VALUES (:1);", (image_bytes))
Do you have any idea how that works? I'll try other methods
FSXManu
« Reply #12 on: March 09, 2022, 11:48:18 pm »
You have to pass a single string to Repository.Execute, so more like:
repo.Execute("INSERT INTO T_DOCUMENT (BINCONTENT) VALUES (image_bytes)")
« Reply #13 on: March 10, 2022, 02:12:49 am »
Having "image_bytes" replaced by the real bytes. If that's binary you will have a hard time.
FSXManu
« Reply #14 on: March 16, 2022, 12:37:25 am »
Okay I managed to create an entry in the t_document with my image.
But I struggle to link the document entry to a diagram. Any ideas? I tried to add an entry to diagram.DiagramObjects collection but it doesn't work.
FSXManu
