Author Topic: When does the QL offer the "reversed" connector  (Read 10665 times)
« on: March 03, 2022, 02:18:58 am »
I have defined a two constraints from a (stereotyped) actor to a (stereotyped) use case. From the use case towards the actor I defined a <<metarelationship>> UseCaseLink and a <<stereotyped relationship>> primary (extending UseCaseLink). Now when I drag the QL from UC onto actor EA shows both connectors in the dropdown. But the other way around it only shows the <<primary>> and not the plain UseCaseLink. Why is that so?
P.S. Also dragging onto blank space from the actor only shows the stereotyped connector with the use case, not the UseCaseLink.
« Last Edit: March 03, 2022, 02:23:46 am by qwerty »
Re: When does the QL offer the "reversed" connector
« Reply #1 on: March 07, 2022, 09:12:42 am »
In short, you can't. The quicklinker doesn't show multiple relationships with the same label, so you need to give a different label for the reverse connector.
You do this for stereotyped relationships by defining _MeaningBackwards on your connector stereotype.
You can't change the definition of the UML connectors so you can't do that.
« Reply #2 on: March 07, 2022, 07:26:39 pm »
That's unfortunate. Would it be possible for Sparx to think over a remedy for this?
