Author Topic: Flow Properties compartment not available  (Read 5450 times)
PeteC
« on: March 05, 2022, 02:40:29 am »
If I create a SysML Block Definition diagram, add a Block and to the block add a Flow Property then the item appears on the block in the "flow properties" compartment. The compartment can be toggled from the diagram properties to be visible or not.
If I drop a link to the same block on my custom diagram, the flow properties compartment cannot be displayed on the block; it does not even appear in the list of available compartments in the Show Compartments section of the diagram properties.
What do I need to add to my custom diagram definition in my MDG for it to work the same as the SysML diagrams?
Re: Flow Properties compartment not available
« Reply #1 on: March 07, 2022, 09:01:08 am »
Right now, the only way to do that is to use a view specification to add an available view to the original SysML diagram.
PeteC
« Reply #2 on: March 08, 2022, 10:57:06 pm »
So how would I do that?
I already have a View Specification that extends my custom diagram and exposes my desired elements and relationships.
Adding an extension from my existing View Specification to SysML1.4::BlockDefinition only results in adding my defined View Specification to a SysML Block Definition diagram, not adding the ability to display the "flow properties" compartment on elements on my custom diagram. What it did is what I expected the way I defined it from how I understood View Specifications to work.
I can't see anything else in the documentation explaining how to achieve what I wanted. I am wondering if from what you are suggesting I need to related my View Specification to SysML1.4::BlockDefinition in a different way.
« Reply #3 on: March 09, 2022, 08:11:54 am »
Then you have it working.
It does not change your diagram definition. It's completely unrelated.
No. You just need to use the view specification from the SysML block diagram.
PeteC
« Reply #4 on: March 09, 2022, 10:20:07 pm »
OK, but I was trying to get the flow properties compartment to appear on my custom diagram type, not a SysML diagram.
« Reply #5 on: March 10, 2022, 08:14:45 am »
The flow properties compartment is specified by the SysML diagram types. You can't inherit from them, so the only way to have a customized diagram using them is a view specification extending the original SysML diagram.
That means, you need to choose between a completely new diagram type or having the SysML functionality.
