Author Topic: underlined table column in class diagram  (Read 4489 times)
marcel700
« on: March 10, 2022, 01:39:43 am »
Hello all,
i would like to ask you to help me with this "problem". I did some reverse engineering in EA and after importing tables via database builder i noticed that some tables in class diagram have underlined some columns. I was able to find out that underlined attribute in class means static attribute, but i can't find out what this means for tables. Can somebody help me with this?
Modesto Vega
Re: underlined table column in class diagram
« Reply #1 on: March 10, 2022, 04:15:09 am »
This is a long shot, are the underlined columns/attributes a calculated field - i.e., do they have a formula? Or, do they have a default value?
Takeshi K
    • Sparx Systems Japan
« Reply #2 on: March 10, 2022, 09:54:20 am »
Hello marcel700,
For tables, underlined columns have 'unique' constraints.
t-kouno
marcel700
« Reply #3 on: March 10, 2022, 11:43:49 pm »
Thank you, i checked it out and it seems it is as you said, for the unique constraints. I was not sure because if i have unique constraint on two or more columns, EA doesn't underline the last column. I also tried more unique constraints in table a it only didn't underline the last column of the first unique constraint and the other were OK - all columns underlined. So it seems it is some kind of bug in EA. I use 13.2 version, maybe it's fixed newer versions.
