Author Topic: ClearCase XML Export  (Read 3304 times)
PhilippW
« on: March 21, 2022, 08:47:37 pm »
Hi all,
I am currently using the integrated Version Control Mechanisms for ClearCase version control in EA. In my versioned package structure in EA I have a hierarchical structure where versioned packages contain multiple versioned packages too over several layers. Now I am switching to another version control system which is not supported by EA so I need to export/import and version control the packages manually.
So now comes the problem/question.
I could see, that the xml files which were exported by the CC mechanisms in EA do have a different structure/layout than manually exported xml packages (tried several export options). In the CC exported packages, there are references to the versioned "sub-packages". This information is not available in the manually exported ones.
Is there an option to manually trigger the export mechanism which is used by the integrated CC check-in? Or does anybody know the specific format which is used for CC?
I would like to use this mechanism to export the packages manually and bring them on my new version control system.
Thanks in advance.
Philipp
« Last Edit: March 21, 2022, 08:49:30 pm by PhilippW »
Re: ClearCase XML Export
« Reply #1 on: March 21, 2022, 09:02:32 pm »
Philip,
If you set the version control system in Package VC to (None) you can work in exactly the same way as before. There is an option to include sub-packages or not.
Having used this option you can export all of your XMI's in one go using Publish | Model Exchange | Batch export controlled packages
