Author Topic: Own structured scenario template in reports  (Read 5722 times)
Slávek Rydval
    • homepage
« on: March 31, 2022, 01:44:18 am »
I am preparing a custom report and need to create own teplate for structured scenarios. First of all, I have a template that shows a diagram of a package, where use cases are shown, and after that I have a list of these use cases. The use cases are NOT from the same package as the diagram is. Now, I need to show all structured scenarios, each separated from each other.
Do you have any idea, how to do it? I tried fragments but you cannot have a fragment (getting all the steps of particular scenario) in a fragment (getting all scenarios).
The pripary template look like this:
package >
{Pkg.Name}
diagram >
{Diagram.DiagramImg}
element >
{Element.Name}
{Element.Name} {Element.Notes}
Scenarios
What should be here?
< element
< diagram
< package
Thanks.
PS.: I know there is option to use from context menu Insert field --> Structured Scenario Text, but you cannot format it if the element is taken from diagram. An the default result is painfull.
Re: Own structured scenario template in reports
« Reply #1 on: March 31, 2022, 04:04:10 am »
Best look into virtual documents.
That allows you to combine elements from different packages using different templates.
Slávek Rydval
    • homepage
« Reply #2 on: March 31, 2022, 07:47:06 am »
Best look into virtual documents. That allows you to combine elements from different packages using different templates.
I am using it already. The thing is the use cases are not from one single package so virtual document is not a solution to this.
Slávek
« Reply #3 on: March 31, 2022, 03:28:21 pm »
Slávek
Why not? I'm often using model documents for single elements, using a search with the GUID as parameter.
Slávek Rydval
    • homepage
« Reply #4 on: April 01, 2022, 10:48:12 pm »
How? As you can see on the template I posted, I can insert fragment on the line
Scenarios
In this fragment I am able to insert all the structured scenarios (names) via SQL or Script. But I am not able to each scenario insert all its lines (it should be another fragment getting id of scenario as a parameter). Or am I missing something?
Cheers.
Slávek Rydval
    • homepage
« Reply #6 on: April 02, 2022, 04:11:40 am »
