Author Topic: When I generate document, notes dispaly messy code. 手机号  (Read 8890 times)
ea0921
For example:
employeeId : String  Private
员工编号
[ Is static False. Containment is Not Specified. ]
My EA version is 16.0.1604 64 bit
My OS is windows 11 chinese.
You  can lookup the unicodes here:
#21495 mean 号 (means Number if I'm remembering my Japanese correctly). Leave the rest to you ;-)
Takeshi K
    • Sparx Systems Japan
Yes, 号 is used for numbers (but also for others) in Japanese, but these 4 characters seem Chinese. They contain some characters which are not used in Japanese Kanji characters.
t-kouno
ea0921
Yes , it is chinese。
but how can i display these characters correctly when generating document。
You'll have to be a bit more specific?
Which template do you use to generate the document?
How does it look in the GUI? Do you see the real characters, or also the unicode codes.
ea0921
yes,I can see the real characters in the notes window.
This is equally as important. If you are using a script or SQL fragment, without telling EA it's a formatted field, you'll get these type of things.
ea0921
I use the built-in template of the system.
There are several built-in templates.
The default one (Model Report) is actually a very complex combination of many templates depending on the type of element.
Without knowing all the details it's hard to help.
ea0921
All template display notes information in messy code.
My OS code is GBK.
The coding of notes seems to be utf8
It seems to be caused by this problem.
