Author Topic: EA Cloud Connection (E_Fail Status error)  (Read 29709 times)
Stark798
« on: April 28, 2022, 09:37:42 pm »
 :( I have PCS 5.0.104, While connecting to a model through the cloud connection, EA throws an error stating "Data Provider or Other service returned an E_Fail Status". Please check the image below,
« Last Edit: April 28, 2022, 09:51:29 pm by Stark798 »
wivel
  • Driven by Models
Re: EA Cloud Connection (E_Fail Status error)
« Reply #1 on: April 29, 2022, 10:13:16 pm »
Hi
Quick questions:
  • Have you upgraded PCS from 4.x to 5.x or is it a new install?
  • If you have upgraded, did it work before the upgrade?
  • Which version of EA are you using?
  • Do you know which database type it connects to?
  • How do you connect to the database from PCS? Native or via ODBC?
  • Can you connect to the database from the PCS setup?
  • Can you connect to the database directly from EA?
  • Have your network changed, e.g. new IP address for the database and/or PCS Server
Will help when trying to chase down your problem.
Henrik
Stark798
« Reply #2 on: May 02, 2022, 03:32:51 pm »
Hi
Quick questions:
Henrik
Sorry for the late reply @wivel,
1. Yes, we upgraded from PCS from version 4.2 to 5.0.104
2. It worked without any issues before the upgrade.
3. EA 16.0.1604 64-Bit.
4. This connects with the MSSQL Database.
5. This occurs when connecting the DB with the Cloud Connection.
6. Yes.
7. Yes, Server connection is successful without any issue.
8. No, Nothing Much.
STARK
wivel
  • Driven by Models
« Reply #3 on: May 04, 2022, 11:13:45 pm »
Hi Stark
Really strange. Since you can connect to the DB from both eA and PCS, it must be something in the connection between EA and the PCS server. Are you sure nothing has changed in the naming, model numbers, server addresses and the like?
Henrik
wivel
  • Driven by Models
« Reply #4 on: May 05, 2022, 12:25:51 am »
Another question. did you upgrade to PCS 5.x 64 bit version? In that case, you have to follow the migration steps described here: https://sparxsystems.com/enterprise_architect_user_guide/16.0/the_model_repository/pcs-64bit-migration.html
Henrik
Stark798
« Reply #5 on: May 05, 2022, 03:01:50 pm »
Thanks Henrik. Yes, I have upgraded from PCS 5.x 32-Bit version to 64-Bit. And thanks for the 'Migration steps' info, No one was aware of this. After creating a new connection I was able to connect without any issues. Thanks for the reply ;D :P
Stark 8)
wivel
  • Driven by Models
« Reply #6 on: May 05, 2022, 09:40:59 pm »
Hi Stark
Glad you got it to work. I sort of stumbled onto the migration steps by accident myself. There is a link to it from the PCS download page in the 'Installing and Registering Pro Cloud Server v5' section.
Henrik
Stark798
« Reply #7 on: May 05, 2022, 10:34:56 pm »
Thanks Henrik  ;D ::)
