Author Topic: SQLite Can't add 1+1?  (Read 4798 times)
Nigel_Simpson
« on: May 04, 2022, 08:44:00 pm »
I'm new to SQLite SQL so please can someone help explain why this SQL:
select 1 + 1 as two, typeof(1) as onetype, typeof(1 + 1) as twotype
from t_object
limit 1
returns 11, integer, text
Is there a very different approach to standard arithmetic in this database?
Richard Freggi
Re: SQLite Can't add 1+1?
« Reply #1 on: May 04, 2022, 08:48:45 pm »
Read up on sqlite.org, your syntax is off (SQLite is ANSI SQL, your query is not)
Nigel_Simpson
« Reply #2 on: May 04, 2022, 09:01:10 pm »
Please could you be more specific? What is the syntax I have done incorrectly?
Richard Freggi
« Reply #3 on: May 05, 2022, 12:57:47 am »
Your query runs on my native SQLite (I don't have EA V16)
By ANSI SQL I meant
SELECT 1+1 AS "Two", typeof(1) AS "Type1", typeof(1+1) AS "Type2"
|Two|Type1  |Type2  |
|2   |integer |integer |
SQLite defaults to TEXT datatype whenever possible, so it may be the EA 16 SQLite driver that's playing games on you
« Last Edit: May 05, 2022, 01:02:38 am by Richard Freggi »
Nigel_Simpson
« Reply #4 on: May 05, 2022, 02:03:19 am »
By ANSI SQL I meant
|Two|Type1  |Type2  |
OK thanks for the clarification. I still have the problem if I just issue:
SELECT 1 + 1
I'm sure it will be the EA16 driver as you say. I've reported a bug.
Richard Freggi
« Reply #5 on: May 05, 2022, 02:50:18 pm »
It's treating "1" as TEXT datatype, so it's concatenating 2 strings
