Author Topic: Running EA15 and EA16 on same computer  (Read 4639 times)
DeBAAT
« on: May 05, 2022, 02:30:52 am »
With the introduction of EA16, there is the option to migrate an EAPX file to QEAX format, changing the underlying database as also indicated in another topic.
In my case, I would like to run both EA15 and EA16 on my same pc as I use different file repositories for different customers who are not migrating at the same pace.
What would be needed to make this happen?
I already installed the new EA16 on a test machine and it seems to run the out-of-the-box functionality but it looks like I'm missing the add-ons like EAUtils or the Bellekens Tools.
Any suggestions?
Re: Running EA15 and EA16 on same computer
« Reply #1 on: May 05, 2022, 04:31:55 am »
If you rename the program files folder for EA to something else (e.g. EA v15.2) you can then install v16 on the same machine.
My add-ins currently only work in the 32bit edition. I still have some work to to make them compatible for 64bit.
DeBAAT
« Reply #2 on: May 05, 2022, 03:06:44 pm »
Ah, thanks for the reply.
It looks like both EA15 and EA16 already work both on the same computer because I installed EA16 64bit version which is installed in a different folder ("Program Files" vs "Program Files (x86)").
And your suggestion about the 32bit version might also apply to the other add-ons I have installed.
Hope this will be fixed soon.
