Author Topic: Default orientation for activity partition  (Read 6055 times)
bechbp
« on: May 05, 2022, 02:03:25 pm »
The default orientation for activity partition is the horizontal orientation. Is there a way to change that default to be vertical orientation?
Thank you
David Rains (bioform)
Re: Default orientation for activity partition
« Reply #1 on: May 06, 2022, 12:06:36 am »
Yeah that would be nice for sure!
« Reply #2 on: May 06, 2022, 12:38:33 am »
There a good chance the project template package might work for this.
« Reply #3 on: May 06, 2022, 12:43:07 am »
I just did a quick test, and it works. If you create a vertical activitypartition in the project template package, the default orientation changes to vertical.
« Reply #4 on: May 06, 2022, 05:19:53 am »
https://sparxsystems.com/enterprise_architect_user_guide/15.2/modeling/using_element_templates.html
Toward the bottom explains HOW to manage the project templates: ... You can create the Templates Package anywhere in your model; however, it is better to create it in a location that is not likely to be accidentally changed or lost in any project development work.
Set up the Element Templates Package
Thanks as Always Geert!
bechbp
« Reply #5 on: May 10, 2022, 01:40:36 am »
Thank you all for the advice. I will try out the template option and report back.
bechbp
« Reply #6 on: May 10, 2022, 02:26:00 am »
I just tried it out and it worked seamlessly!
Thanks so much.
