Author Topic: [Prolaborate 4] menu not available when opening an element from a report  (Read 36728 times)
Guillaume
    • www.umlchannel.com
In Prolaborate 4.1.2, I created a custom report with a query (dashboard). When I click on the name of an element from the report, it opens the properties but the top right menu is not available (Properties, Discussions, Usage, Traceability...)
This menu is available when I open the same element from a diagram.
It seems to be a bug as one would want to navigate from a report to the views for instance.
Note: here is the start of my query
select t_object.ea_guid as CLASSGUID, t_object.object_type as hide_BaseType, t_object.stereotype as hide_Stereotype,t_object.Name ...
Guillaume
Guillaume
Hi Guillaume,
Thank you for the note. Yes, this seems to be a bug and our team has also confirmed it.
This will be fixed in the next immediate release.
Guillaume
Thanks !  :D
Guillaume
Guillaume
I also noticed the "Open" button (bottom left corner) is not available when open the properties of the last element in the report.
Guillaume
Hi Guillaume,
This issue item was fixed in the latest version 4.2, which should be available by mid of June 2022.
« Last Edit: June 04, 2022, 11:44:30 pm by Arshad »
