Author Topic: Old Test Case Element  (Read 6117 times)
philchudley
« on: May 10, 2022, 06:10:56 pm »
Hi All
I am working a repository for a client that was created quite a few years ago and in one section models Test Cases. These elements are rendered, as Use Case elements with a bold black X in the top, on a Use Case diagram.
On older versions of EA this used to be (incorrectly IMHO) in the UML Use Case Diagram toolbox.
When one of these test case diagrams is opened in EA v 15.2, the test case element is not in the diagram tool box, but is rendered correctly with the bold black X.
Does anyone out there know where this old test case element is located, which MDG should be used?
Of course copying an existing element and pasting as new works, but I would still like  to know how create one these old test case elements from scratch.
I have tried creating a UML Use Case and assigning the stereotype <<testcase>>, but that just produces the text <<testcase>> in the Use Case and not the bold black X.
Phil
Models are great!
Re: Old Test Case Element
« Reply #1 on: May 10, 2022, 06:21:38 pm »
You can find it in the Construction toolbox.
I think it's one of those Extended EA things, but I wouldn't know which MDG exactly.
philchudley
« Reply #2 on: May 10, 2022, 07:14:50 pm »
Many thanks Geert
See you at the EAUG 2022 in Reading
All the best
Phil
Models are great!
« Reply #3 on: May 10, 2022, 07:18:19 pm »
Many thanks Geert
All the best
Phil
Yes, indeed, it has been too long since we had an IRL event.
For those wondering, there are still tickets available: https://www.eausergroup.com/
