Author Topic: Problem with creating relation to Junction in Archimate model  (Read 3807 times)
Karol Kordziński
I don't know if this is a bug so first I describe the issue. EA 15.1.1526
I had some repository on my local computer next I had to import it to the next computer to the corporate repository. After all, I couldn't connect any step process with Junction in Archimate diagrams. When I put arrows on the junction element nothing happened. Arrow just disappears without connection.
The connection between existing elements in imported diagrams appears normally. But when I delete (permanently) the connection I couldn't create it again.
It is wired when I create some new project. The problem is still the same. Even in a new diagram, I couldn't connect the process to Junction.
Maybe I put some keyboard shortcuts and turn some options?  Maybe you can help investigate what option this could be.
Thank you
Re: Problem with creating relation to Junction in Archimate model
« Reply #1 on: May 10, 2022, 09:25:19 pm »
Can you be a bit more specific?
I don't know any Junction or step process objects in Archimate.
Also important to know which version of ArchiMate you are using.
You can't mix versions.
« Reply #2 on: May 11, 2022, 08:52:24 am »
As a theory (15.1 is old enough that I can't remember precisely) the rules for linking a junction to the other ArchiMate elements is more complicated than the rest. I'm not sure we had the checks right in that version. I'd try turning off strict connector syntax until you can upgrade.
