Author Topic: Setting the Default Attribute Type in MDG  (Read 3338 times)
Christer Lindh
« on: May 17, 2022, 04:13:26 pm »
I've created an MDG with a code module. When importing it in my model my language appears in the section Source Code Engineering in the private Preferences dialog with the "Options for the current user" containing "Default Attribute Type". But I can't change it! It becomes grayed out when I select it and I can't enter or select any value. According to "Eve" in the topic https://sparxsystems.com/forums/smf/index.php/topic,43998.msg259685.html#msg259685 it should be possible, if I understand it correctly...
Even better would be if I could have the Default Attribute Type as a code option in the MDG, but it doesn't seem to be among the possible options according to this: https://sparxsystems.com/enterprise_architect_user_guide/15.2/modeling/define_code_options.html.
All I want to do is to define my own datatypes and set one of them as default. The first part is easy, but I don't manage to set the default (which continues to be "int"). Any suggestions?
