Author Topic: Generate Sequence Diagram - BasicPath diagram name  (Read 3028 times)
jami
  • ekhm
« on: May 18, 2022, 11:40:27 pm »
How can I set the name of the generated sequence diagram from the UC main scenario to match the name of the UC and not all the diagrams are named BasicPath?
EA takes this name from the scenario type, not its name. Can this be changed somewhere?
Except for manual renaming? :)
Re: Generate Sequence Diagram - BasicPath diagram name
« Reply #1 on: May 18, 2022, 11:51:21 pm »
No you can't configure that. You can however create a script to rename them if this is a burden to do manually.
And of course you can send in a feature request to Sparx. Use the link on the bottom of this page.
jami
  • ekhm
« Reply #2 on: May 19, 2022, 12:06:47 am »
Thank you very much for your quick answer  :)
