Author Topic: Copy default shape of block to generated parts  (Read 3763 times)
Mercurius
« on: June 01, 2022, 03:06:31 am »
Hello All,
I would like that a defined default image or shape of a block (class) is also automatically applied to the parts (objects) generated from that block. Is that possible?
I have done the following:
  • Defined a new stereotype (extending "class", generalizing "SysML1.4::block", with an indivdual ShapeScript)
  • Created and activated an MDG including this stereotype
  • Build a BlockDefinitionDiagram with a block of the new type (-> The Shape appears as desired.)
  • Connected the block via a "part association" to a parent block (-> The "part"/"object" is generated as desired.)
  • Added an internal block diagram (IBD) of the parent block
Now the Part in the IBD appears in the standard way. But I would like to see the shape defined for the original block/class.
Can anybody help? Thanks in advance.
Re: Copy default shape of block to generated parts
« Reply #1 on: June 03, 2022, 08:09:48 am »
You will need to define a stereotype that extends Part that also has a shape script. Also set the _instanceType of the Class stereotype to the Part stereotype (search help for 'instanceType' for details)
Mercurius
« Reply #2 on: June 05, 2022, 02:36:29 am »
Cool. It worked. Thank you a lot, KP.  :)
