Author Topic: Adding technology to strict set selects nothing by default  (Read 8218 times)
« on: June 01, 2022, 05:42:38 pm »
When adding a new technology to a strict model based perspective set, nothing in that new technology is selected by default.
You have to manually select all the elements, diagrams etc... before they can be used.
The default should be that everything is selected, so you can uncheck what you don't need.
Reported
Re: Adding technology to strict set selects nothing by default
« Reply #1 on: June 01, 2022, 09:19:27 pm »
Reported
Wot 'e sed!
« Reply #2 on: June 03, 2022, 02:02:24 pm »
Got feedback from Sparx
Thank you for your enquiry. Our developers have provided the following feedback, please see:
While I can see why you would expect that, I don't think it's as clear cut as you're suggesting.
The behavior you are describing is only present when there is a restriction applied. That restriction is saying that only specific types from the selected technologies are available. For adding a new technology to an established restricted perspective there's no reason to think that the default behavior when adding a new technology would be to include everything.
Yes, it makes sense that the user would want at least some types from the new technology. In an already tight restriction it makes sense to require explicit selection of the newly allowed types.
Hope that helps. If you have further questions please let us know.
Pff, what a load of nonsense. Incredible :(
« Reply #3 on: June 03, 2022, 05:14:15 pm »
User: "I have a good idea."
Sparx: "Well, fine. But could you keep that for yourself?"
« Reply #4 on: June 03, 2022, 06:00:04 pm »
Yes, it makes sense that the user would want at least some types from the new technology. In an already tight restriction, it makes sense to require explicit selection of the newly allowed types.
Sparx has always had a problem creating a useful user Selection experience. See my many posts in the past.  They appear to be living in the 1980s when User Experience was not considered.
As Geert said "Pff"!
