Author Topic: Reverse Engineering Questions  (Read 32563 times)
ilan88
« on: June 07, 2022, 04:55:31 pm »
I have successfully reverse engineered UML class diagrams for each folder in my project, and I have some follow-up questions:
1. Is it possible to reverse engineer package diagrams from code?
2. Is it possible to link reversed package diagrams to reversed class diagrams? So I can click a package and go to the related class diagram.
3. Is it possible to *automatically* display related classes from other folders / packages in reversed class diagrams?
    -  For instance, if I have class X from package A, and class Y from package B, where Y is derived from X, is it possible to:
       *  Display class Y is the class diagram of package A as a derived class of X
       * Display X in class diagram of package B as parent class of Y
Thanks!
Re: Reverse Engineering Questions
« Reply #1 on: June 07, 2022, 05:56:54 pm »
No
If you create your diagram in your package, it will automatically be linked.
If you want another diagram to open, you can right click on a package in a diagram, and choose New Child Diagram | Select Composite Diagram
Thanks!
You could make a script that adds related classes to diagram.
There is standard function available, but the context menu option Insert Related Elements does help a lot when doing it manually
