Author Topic: Duplicated Fields on data element in SPARX  (Read 2823 times)
Mintra
« on: June 14, 2022, 02:22:09 am »
The tagged Values field shows multiple values in WebEA as below. How do we fix the issue?
Tagged Values
Comment = Field Label = First Name
Comment
Comment
Comment
Control Type = Textbox
Default Field Value = N/A
Default Field Value
Default Field Value
Default Field Value
Default Field Value
Field Description
Field Description
Field Description
Field Description
Field Description
Field Length = 26
Field Length
Field Length
Field Length
Field Length
It is supposed to look like the below:
Tagged Values
Field Description
Field Length = 26
Re: Duplicated Fields on data element in SPARX
« Reply #1 on: June 14, 2022, 02:28:41 am »
I'm pretty sure that are the actual tagged values that exist in the model.
There is an option in the tagged values window to show duplicate tagged values or not.
I'm guessing you don't have that option checked, and thus EA is hiding the duplicates for you.
Mintra
« Reply #2 on: June 14, 2022, 02:37:52 am »
Hi Geert,
Thanks for your insights. It works!
« Last Edit: June 14, 2022, 02:53:04 am by Mintra »
