Author Topic: SQLite is way faster than SQL Server  (Read 8224 times)
« on: June 16, 2022, 05:35:33 pm »
I've been doing some performance tuning on one of my add-ins (EA Message Composer) and I noticed that a model in SQLite is a lot faster than a model in SQL Server (running on my local machine)
For one testcase I have a process that takes somewhere between 250 and 300 seconds in SQL Server, and only 100 seconds in SQLite.
Other things like applying user locks on a big part of the model also seem to be much much faster.
Anyone seeing the same results? Any ideas of what I could do to speed up my SQL Server?
Because of this, having a central database such as SQL Server comes with a serious performance penalty, making it a lot less attractive.
wivel
  • Driven by Models
Re: SQLite is way faster than SQL Server
« Reply #1 on: June 16, 2022, 11:57:09 pm »
Hi Geert
Perhaps this can point you in the right direction? https://docs.microsoft.com/en-us/sql/relational-databases/performance/database-engine-tuning-advisor?view=sql-server-ver16
Here is what I did:
  • Opened SQL Server Management Studio
  • Started the Profiler (Tools -> SQL Server Profiler)
  • Selected to save to a file
  • Pressed the 'Run' button
  • Played around with EA
  • Stopped the profiler
  • Opened the Database Engine Tuning adviser (Tools -> ...)
  • Selected the trace file I just generated
  • Sat 'Database for workload analysis' to my EA database
  • Selected my EA database in 'Select databases and tables to tune' to my EA Database
  • Pressed 'Start Analysis' and let it finish
Let it run and it will provide you with a list of suggestions to make the database perform better. I got a lot of Index suggestions on the small test I just made. To get a more accurate result, the profiler should run for a longer period under normal workload conditions.
Henrik
« Last Edit: June 17, 2022, 12:41:26 am by wivel »
Richard Freggi
« Reply #2 on: June 17, 2022, 12:32:16 am »
Hey Geert,
I'd be be curious to know if you have found a way to make the SQLite repository work in-memory ("file::memory:" parameter).
I don't know if EA supports this repository mode, and it would not be ACID until the database is saved to disk.  But potentially it could be a real ripper!
p.s. also PRAGMA journal_mode = off and PRAGMA synchronous = off may speed even further if EA can tolerate them.
« Reply #3 on: June 17, 2022, 12:44:47 am »
Thanks Henrik,
Will definitely try that.
The problem is that I don't want to update the standard EA database schema, so I'm specifically searching for other ways to improve the performance.
EA's database use is pretty specific. It executes lots of tiny queries.
Maybe there are some parameter we can tweak to make SQL server handle this type of load better.
« Reply #4 on: June 17, 2022, 12:46:15 am »
Hey Geert,
I haven't tried anything on the SQLite side, but I can understand why this could potentially be interesting.
wivel
  • Driven by Models
« Reply #5 on: June 17, 2022, 01:00:43 am »
Thanks Henrik,
I fully understand. I didn't pull the trigger either for the same reasons. I'm not that well versed in what the MS SQL tools can do, so perhaps it can come up with suggestions that does not touch tables, indexes and the like.
Henrik
« Last Edit: June 17, 2022, 01:13:03 am by wivel »
