Author Topic: Code generation path  (Read 3300 times)
Toth, Istvan Zoltan
« on: May 07, 2013, 01:02:59 am »
my colleague made project with a modified transformation. He sent me the .eap file to test the transformation. Now when I try to transform a class into Java code (with CTRL-H) the program tries to write the code into the directory which my colleague used.
How can I change the directory of the Java source in this case?
Thank you,
Kind regards,
Istvan Zoltn toth
DanG83616
Re: Code generation path
« Reply #1 on: May 08, 2013, 03:17:06 am »
See Local Paths and Directories under Settings.
