Author Topic: Timeout Pro Cloud Server  (Read 4694 times)
Helmut Ortmann
« on: June 23, 2022, 09:51:17 pm »
If I use a query with the Search Window I get an EA TIMEOUT error after around 30 seconds.
If I use the C#/VB API I get after around 30 seconds an empty result. No indication of an error except the empty result occurs.
Can and how can I modify the TIMEOUT time?
Thanks and best regards,
Helmut
wivel
  • Driven by Models
Re: Timeout Pro Cloud Server
« Reply #1 on: June 23, 2022, 10:53:24 pm »
Hi Helmut.
Which version of EA and PCS are you running? In the later versions of EA 15.2 and PCS 4.2x, (cant remember the actual build numbers) there is an option in EA to set at timeout value.  Its located at Configure -> Options -> Cloud -> Maximum Query Time.
Hope this helps.
Henrik
Helmut Ortmann
« Reply #2 on: June 27, 2022, 09:38:39 pm »
Hi Henrik,
I've found it:
Helmut
