Author Topic: Any easy way to get the SysML IBD block look like a UML component ?  (Read 2890 times)
avi10000
  • Programmer/Writer
Hi all,
Is there any easy way to get the SysML IBD block to look like a UML component - i.e., the UML component has a "widget (interface?) sort of icon" at the top right corner. (widget icon is a small rectangle - higher than it is wide -- with two little rectangles sticking out its left side.)
Something like the below. Best to zoom out to see this well :
Thanks, all. And have a good weekend.
Avi
Re: Any easy way to get the SysML IBD block look like a UML component ?
« Reply #1 on: June 25, 2022, 05:40:24 am »
No SysML specialist, but AFAIK they define their own elements and you are obliged to use them - if you want to be SysML compliant. However, it's also possible (if you document that) to use basic UML elements like UML components in a mix.
« Last Edit: June 26, 2022, 07:43:41 am by qwerty »
avi10000
  • Programmer/Writer
« Reply #2 on: June 26, 2022, 06:29:03 am »
Very good point.
Thanks and have a good weekend
Avi
