Author Topic: [Ask] column name with space on Custom Report Prolaborate  (Read 79375 times)
demian824
Hello, I wonder how to put space with letter for column name on custom report. (i.e. Business Owner, not Business_owner)
Could you please help me to solve the problem? I put my query on the board.
select
   obj.Name as Name,
        bo.Value as "Business_Owner",
   boe.Value as "Business_Owner_Email",
   comp.Value as "Component",
   ces.Value as "Core_Enterprise_Shared"
from
        t_object obj
inner join
   t_objectproperties bo
on
   (obj.Object_ID = bo.Object_ID
and
   bo.Property = 'Business Owner')
inner join
   t_objectproperties boe
on
   (obj.Object_ID = boe.Object_ID
and
   boe.Property = 'Business Owner Email')
inner join
   t_objectproperties comp
on
   (obj.Object_ID = comp.Object_ID
and
   comp.Property = 'Component')
inner join
   t_objectproperties ces
on
   (obj.Object_ID = ces.Object_ID
and
   ces.Property = 'Core / Enterprise Shared')
Re: [Ask] column name with space on Custom Report Prolaborate
« Reply #1 on: June 28, 2022, 02:25:55 pm »
Depends on the database you are using.
For some (SQL Server, .eap) it's as [Business Owner] whereas for others you need backticks: as `Business Owner`
demian824
« Reply #2 on: June 28, 2022, 11:13:01 pm »
Hello Geert,
I tried both brackets and reversed quotation marks. I use data from EA. Without space and any symbols, it was worked well. However, it was not worked on custom query.
Thanks.
OpenIT Solutions
« Reply #3 on: July 05, 2022, 04:03:15 pm »
Which version are you using. I know in 3.6, this was fixed. You can have spaces in column names. Not sure re v4.x. However i'm told there will be a new version, 4.2 release very soon. So maybe hang on a few days and try with the new version when its released if you on version 4.x
Jon.
demian824
« Reply #4 on: July 12, 2022, 06:13:02 am »
Thanks for your answering Jon.
It helped a lot.
Guillaume
    • www.umlchannel.com
« Reply #5 on: July 20, 2022, 05:49:04 pm »
I confirm that spaces are supported in reports columns with Prolaborate 4.1.2.
Version 4.2 has been released and includes enhancements on reports, based on those seen in 3.6.0.
Guillaume
